May 21, 2013, 05:10:57 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
: SMF - Just Installed!
Help
Search
Login
Register
Sadowsky Basses
Sadowsky Basses
(Moderators:
Bikeplate
VTC & Battery life
Pages: [
1
« previous
next »
Author
Topic: VTC & Battery life (Read 1853 times)
bigRalph
VTC & Battery life
on:
June 14, 2010, 03:25:47 PM »
If I bypass the VTC, does the battery still drain as long as the cable is plugged in?
Re: VTC & Battery life
Reply #1 on:
June 15, 2010, 12:25:43 AM »
Yes
I misread your post earlier.
There is no way to bypass the VTC - it's a passive tone control. You can bypass the preamp.
In any case, as long as a cable is inserted you're draining the battery.
Last Edit: June 15, 2010, 01:40:49 AM by RonenTat
Reply #2 on:
June 15, 2010, 12:52:39 AM »
+ 1
VTC is passive and 'unrelated' to the active on-board preamp with it's bass and treble boost
Reply #3 on:
June 15, 2010, 03:13:20 AM »
Quote from: bigRalph on June 14, 2010, 03:25:47 PM
The one thing in common between the VTC and the preamp bypass switch is that they share the same pot, but the VTC is always in the signal chain, active or passive.
Reply #4 on:
June 16, 2010, 07:06:08 PM »
I assume what you mean is "does the battery still drain as long as the cable is plugged in, even if the preamp is bypassed." The answer is YES. The battery switch is built into the jack, not the bypass switch.
Please do not send me messages through the forum. Please email me directly. Thanks.
Reply #5 on:
July 23, 2010, 03:26:03 PM »
Quote from: IntenseJim on June 15, 2010, 12:52:39 AM
+ 1
Yes, but in the interest of clarity, the control still is a passive treble cut in either mode. That is, it will cut the treble in both active and passive mode.
Reply #6 on:
August 04, 2010, 12:13:42 AM »
VTC is a separate entity from the active preamp. When you bypass your preamp, it's the same idea as the bass and treble boost not being there at all. Compare the bypass in both positions with your bass and treble boost knobs rolled all the way back. VTC works the same regardless of the position your active toggle switch or push/pull is set. Also, your VTC will work even if you don't have a battery installed or if you bypass the preamp.
If your battery dies, you will have to bypass your preamp to send a signal at all.
If you notice distortion or volume changes while your preamp is active, it's time for a new battery... also I do believe there are battery testers available through the Sadowsky Online Shop that jack in with an instrument cable on your bass and show a reading for battery life so you don't have to remove your battery for testing.
Pages: [
1
« previous
next »
Please select a destination:
General Category
=> Sadowsky Forum
Sadowsky Basses
=> Sadowsky Basses
=> Sadowsky Guitars
Forum Links
=> Gear Page Links
=> TalkBass Links
Loading...
