May 25, 2013, 07:06:51 AM *
Author Topic: Sadowsky design tweaks timeline  (Read 6285 times)
« on: June 02, 2010, 02:07:28 PM »
All,
I'd very interested if we could assemble a time line of the design tweaks that have been made the the NYC Sadowsky basses.
For example, has the preamp design changed, and if so, when?
When did graphite rods begin to be used in the neck?
When did the VTC come to be?
When did chambering the bodies begin?
When did the PUs go from SD/DiMarzio to Nordstrand?
If there is anything else that adds value, please include that item in the timeline as well.
My interest is in understanding the differences in the basses based on the age. So, that if you run upon a pre-owned bass, you understand what you are looking at?
I know that they are all great, but there has to be some reasons for things changing.
« Last Edit: June 02, 2010, 03:43:52 PM by chasarms » Logged
« Reply #1 on: June 02, 2010, 02:42:58 PM »
Cool idea, I'd also be interested in knowing when they moved to the spokewheel truss rod adjuster.
« Reply #2 on: June 02, 2010, 03:12:28 PM »
That is the greatest Sadowsky 'perk' ever.   I love it; it makes my life so much easier when I change strings or when the seaons changes. I keep my guitars and basses in a room with radiant heat, humidifer, and central AC. But still, every so often I need to make a slight tweak to the truss rod.
« Reply #3 on: June 02, 2010, 04:02:34 PM »
TOTALLY ! With the constant humidity fluctuation that my city goes through - tweaks are part of life. I'm looking forward to this one !
« Reply #4 on: June 02, 2010, 04:50:34 PM »
Every Sadowsky I've owned had a rock solid neck so I've really never had to use it much, but yes the spokewheel is AWESOME!
« Reply #5 on: June 03, 2010, 11:20:02 AM »
If my research is in line, the graphite necks came to used very late in 2003. I don't think the chambering has a hard date. As I understand, they began mixing them in sometime in '03 as well.
If someone believes otherwise, please advise. This of course begs the question: How can you know the date of manufacture on your Sadowsky?
Is there a serial number range by year list out there somewhere?
It would be awesome if this forum could become the definitive source for such things. It's great having Roger Sadowsky himself minding the kitchen. as he can dispell any falsehoods that might arise.
Chas
« Reply #6 on: June 03, 2010, 11:35:14 AM »
Chas
You can see the month/year and builder written inside the control cavity on the back of the bass.
« Reply #7 on: June 03, 2010, 02:27:00 PM »
I think the spoke rod adjuster came in 2002 because it was just a few months after I got my first Sadowsky.
« Reply #8 on: June 03, 2010, 10:42:33 PM »
VTC became standard on NYC's late '03 along with the graphite in the necks and thicker headstock.  I got an NYC about Thanksgiving time that year.  It had the newer neck but did not have a VTC.  I cant remember if it was chambered.  It did weight 8.25lbs so Im thinking it might have been
The present preamp was first used in '90.
« Reply #9 on: June 05, 2010, 04:24:59 PM »
I will do my best to add info to this as I have time.
Spokewheel truss rod adjusters appeared for the first time in 2000.
« Last Edit: June 05, 2010, 04:29:14 PM by Sadowsky » Logged
« Reply #10 on: June 05, 2010, 06:30:02 PM »
I would be curious to when the neck profile changed. My 1988 has a thinner profile than the newer basses I tried.
« Reply #11 on: June 06, 2010, 02:04:48 AM »
Chas
NYC basses only (hand written on the back of the cavity cover).
Metro's have no date on them, as far as I know.
« Last Edit: June 06, 2010, 02:07:34 AM by RonenTat » Logged
« Reply #12 on: June 06, 2010, 09:02:31 PM »
I would be happy to create a timeline chart for visual purposes once I can get my hands on accurate info.  The more info, the better!
« Reply #13 on: June 13, 2010, 08:48:58 AM »
Great,
If possible ad the some Sadowsky backround information with facts or thoughts, that make the desiccion for change things at that moment in the past.
It makes things clear to a lot of readers and it can Help not to repeat the same answers on same questions all the time.  Grin
marchone
« Reply #14 on: June 15, 2010, 02:25:02 PM »
A complete bulleted timeline as a sticky would be nice.
