May 21, 2013, 09:51:11 PM *
Author Topic: Sadowsky Preamp/DI Pedal direct into a power amp  (Read 4311 times)
« on: October 29, 2010, 09:23:25 PM »
Just curious if any of you have run a Sadowsky Preamp/DI pedal straight from the XLR out into a power amp, and what you thought of the results?
Thanks.
RMCat
« Reply #1 on: October 29, 2010, 09:44:51 PM »
on a slight tangent - is there any difference between the preamp installed in your basses and the pedal unit?
- Rhys
'Your low B could sink the titanic, no iceberg required' - nicest thing anyone ever said to me
NYC M24F5 #5668
NYC M24F5 #5685
NYC Vintage 5 #6111
and a few Alembics etc...
« Reply #2 on: October 29, 2010, 09:47:10 PM »
- Rhys
The basic preamp circuit is the same but there is a lot of other stuff going on in the box:
XLR line level out
1/4 instrument level out
Mute switch
Tuner out
Etc
« Reply #3 on: October 29, 2010, 09:53:39 PM »
I have a feeling 99.999% of the people on this board who play bass have a Sadowsky bass(es).
Hence, they'd have little need if any for the outboard preamp.   No?
RMCat
« Reply #4 on: October 29, 2010, 10:01:17 PM »
but it is a DI too, and there's a huge difference between units - you can pay $50 or $2000 just for DI. They're not a glamorous piece of gear, but I find a good one extremely important. I think I'll pick one up on monday and give my opinion then.
- Rhys
« Last Edit: October 29, 2010, 10:13:35 PM by RMCat » Logged
NYC M24F5 #5668
NYC M24F5 #5685
NYC Vintage 5 #6111
« Reply #5 on: October 30, 2010, 04:06:29 AM »
Thanks.
Sorry I can't directly speak to your question because I don't have separates.
With my passive Fender P-Bass I have only used the 1/4" out on mine & have plugged it into the return on the effects loop of my Mesa Walkabout (power amp in). I still prefer running it through the regular instrument input because I can then use the GREAT (minimal) passive mid shelving on the Mesa IF it is warranted. I don't even use the padded input. (It's just like running an active bass). That Walkabout has a superb active bass shelving but the active b. boost on Sadowsky bass pre smokes it. I run the Mesa FLAT & use it's 3 band para eq. to remove - never to add.
Now -  For the most part for recording my overdubs I run the 1/4" out from the Sad o/b pre into the high Z  1/4"input of my Avalon U5 > line level 600 ohm XLR bal. out from U5 to XLR bal input of the dbx 160a compressor > unbalanced 1/4" out - because I think it sounds better than the bal. out.  I can't use the XLR out of the Sad pre because (unless I'm missing something) the high impedance (sky high Z) input on the U5 is of course unbalanced.
Won't be long before the pre takes a seat w/ the Fender Roger.  Grin
Hope I didn't put you to sleep. LOL
« Reply #6 on: October 30, 2010, 04:47:06 AM »
Yo Jimbo - Just who are you callin' 00.001% ? LOL.
Oh well ....I've been called worse Grin
« Reply #7 on: October 30, 2010, 04:22:36 PM »
No, Ive never tried it directly in that fashion.  When I had a the DI Pedal, it was used along with non Sadowsky basses.  I would run those basses passive and use ur pre
RMCat
« Reply #8 on: November 02, 2010, 09:50:21 PM »
sorry Roger, it seems my part of Australia has a shortage of Sadowsky pre/DI pedals. Might have to contact your online store and get one shipped. Will give you a review when I get my hands on one
- Rhys
NYC M24F5 #5668
NYC M24F5 #5685
NYC Vintage 5 #6111
« Reply #9 on: November 02, 2010, 11:59:58 PM »
I don't own one, since I use two Sadowsky basses.  Although I may consider putting one in line if I start using my G&Ls live again.
« Reply #10 on: November 03, 2010, 08:06:06 AM »
- Rhys
Did you try my two dealers in Oz?  Bass Gear Direct and The Bass Centre in Melbourne?
R
RMCat
« Reply #11 on: November 03, 2010, 09:19:03 AM »
Hi Roger. I tried the bass centre. It was actually trying a metro in their store that led me to buy a couple of your NYC basses. They're out of stock and are trying to get more before christmas. I like George from BGD, but I figure if I'm going to get it shipped I might as well cut out the middleman and order straight from your online store...
- Rhys
NYC M24F5 #5668
NYC M24F5 #5685
NYC Vintage 5 #6111
RMCat
« Reply #12 on: November 03, 2010, 10:11:17 PM »
take 2 - Bass Centre can supply me with one in about 10 days. Will review for you then
- Rhys
NYC M24F5 #5668
NYC M24F5 #5685
NYC Vintage 5 #6111
RMCat
« Reply #13 on: November 25, 2010, 09:36:10 PM »
finally got my hands on one, but I'm swamped with work and have to fly out to NZ asap, so will post a review when I get back and have time to play with it. Sorry for the delay Roger.
- Rhys
NYC M24F5 #5668
NYC M24F5 #5685
NYC Vintage 5 #6111
« Reply #14 on: December 01, 2010, 11:50:22 AM »
I have done it, sort of, many times.
I do a lot if gigs with no amp -- using either and in-ear system, like the Aviom, or just using the house wedge monitors. I've been doing this a long time and have used a POD, a Sansamp, and all sorts of other active DIs. The Sadowsky is the best DI I have found for this. It's small, light, simple and sounds GREAT for the application.
Ever thought about beefing up the features a bit and putting it in a rack mount chassis?
